CJ-7 Drive Shaft Lenghts after a T-15 to T-18 Swap
Rescue Diver
Full Time Jeeper
Kansas City
1979 CJ-7 with a fiberglass body and 1982 wide track axles, 258 I-6 with a 1995 4.0 head, HEI distributor, Motorcraft 2100 Carb, T-18 wide ratio tranny, Super Lift Springs and 33s, a 1997 BMW 328i, and a 2010 REDLINE CONQUEST TEAM Cyclocross Bike. :)
Oops, I meant T-150 , not T-15 . Too bad we can't edit the title.
I have some questions regarding CJ7 drive shaft lenghts after doing a swap from a T-AMC 150 to a factory original 1979 T-18 out of CJ5 .
Why is it that none of the parts sites seem to offer a rear driveshaft for a 79 CJ-7 with a T-18? I was hoping to find out how long it should be from them.
When they list the collapsed lengths, are they measuring from, the center of the U-Joint cups, the furthest edge of the cups, or are they measuring the actual drive shafts themselves?
The rear driveshaft that came with my jeep, but wasn't the right lenght for front or back with the T-150 is now the correct length for the front with the T-18. It seems to have enough clearance so it won't rub when the suspension is compressed? Is there any reason why I shouldn't use the larger diameter old rear driveshaft on the front?
$35.00
  17.5%
