CJ-7 with Chevy 350
Scrambler GR3
- Alabama, USA
- '85 Scrambler 4.2, T-176, D-300, Custom Dana 489 (rear) w/ elocker, 4.10 gears, Dana 30 (front) w/ elocker and 4.10 gears, 4-5" lift, Toyo Open Country 35x13.5x15 tires
'84 CJ-7 Chevy 350, TH350, D300, stock 3.54 gears, 33x12.5x15 BF Goodrich KM2
I am currently doing a frame-off of a 1984 CJ7 . I have the body off the frame and I have removed the engine. I had planned on rebuilding the engine; however, the engine had a leak in the head gasket and water in the cylinder rusted the block and, according to the machine shop, it is no longer any good. Yes, I learned a lesson. The engine set for about three or four years without running and I was pretty sure it had a bad head gasket. I guess I learned what "ran when parked" can mean. Anyway, I am now weighing different options. I could get another carbureted engine (mid 70's to 1987) because I already have a Holley Throttle Body set up for it along with an intake manifold and rebuild it, or I am considering installing a LS engine.
If anyone has done an LS engine swap into a CJ-7, or if anyone knows of any posts where someone has detailed the process, I would appreciate any assistance or guidance. I understand I should be able to use the engine mounts that were used for the 350.
I have attached a picture of the frame with the original 350 engine in it.
Thanks.
Thanks.
