CJ5 Bumper Gussets?
CJ5 Bumper Gussets?
mhubacek
Olympia, wa
WR450F, 68' CJ-5, 72' CJ-5, F250 POWERSTROKE
Not sure about aftermarket gussets - I would imagine you can get some made pretty cheaply.
Glad to hear your getting those hangers replaced! :)
CJ, do you have a pic of the front of your 72' CJ frame? The frame on my 68' looks alot different then my 72'. With all the cutting the PO did, I'm not sure what it was supposed to look like. The front clip of my 72' is also longer then my 68' front clip. The title says 72'. I thought the front clip was the same until 75. If you don't have a pic available, do you have a measurement of the front frame rail from the front of the spring hanger to end of front frame rail?
CJ, Thank you, those pics will help me greatly. My 72' frame is cut like your 72' in the front. I thought maybe it was supposed to look like the 68' where the width of the frame rail gets taller at the front where the bumper mounts. Right now, my bumper is taller then the frame rails, and there is about a 3/4" gap between my frame rail and bumper where it mounts. Did you eventually add some sort of crossmember to the front of your frame, or weld a piece of square tubing up front for strength in mounting your bumper?
I'm pulling my bumper and fenders off as soon as I get off work, so I'll take detailed close up pics.
I just bolted the bumper to the frame - nothing special. If you have a large gap - sounds like your bumper is fro the wrong year as mine fits tightly to the frame.
My work computer won't allow me on to photo bucket, I guess they want me working or something:D I'll check those pics out when I get home. I guy is coming over tomarrow to give me some suggestions as well, and offer me a quote on the work to be done. Your pics will help me explain to him what exactly what I'm looking for. He's also bringing me a DIY tube fender kit for $200.
Met with that guy yesturday. Looks like I'll be having about a foot of the front of the frame cut back and replaced with new frame rails, new yj spring hangers front and rear, new shock perches front and rear, new shackles, winch plate, new leaf springs mounted, (yj 2" lift springs) for $800. The only extra expense's on my part are the leaf springs and U-Bolts. Everything else is included and installed for the $800. Sound like a good deal? I thought it was, since He's also going to pick it up for me and once the work is complete I should be able to drive it home. I also purchased a high hood tube fender kit for $350(DIY) I will be picking it up next wednesday. :D It does require some cutting to the hood, but provides an extra 3" for tire clearance. There was a post on here awhile ago about tube fenders, The picture I sent then is just a red X now. I'll send you pictures of the high hood tube fenders when I get them.
Petescj, yes those are the same ones, it just took me awhile to get to that point. They are already purchased, and being cut over the next few days. They said probably tuesday. I sent back with him one of my old fenders to use as a template. As long as I don't screw up the welding part, they should look great! I purchased things from him before, and haven't been let down yet.
$20.00
  10.0%
