CJ5 Dana 30 compared to YJ Dana 30
tinhorn
South Coast MA
Street Jeep for snow and ice, still on blocks in the driveway. '73 CJ5, 258 inline six, T18 tranny, Model 20 transfer case, Dana 30/44 w/ 4.27 ratio (soon to be 3.73), original Cutlas hubs, half-cab waiting to be installed. Daily driver is a 20-year-old Mazda pickup.
Are the ring and pinion interchangeable?
I found out that my CJ5 differentials are 4.27 and I'd like a taller ratio for street use. Figured I'd find a complete set of axles to swap, but ran across a 3.07 ring and pinion for the Dana 30 out of a YJ. (I can buy a new ring and pinion in the same ratio for the Dana 44 .)
I'm a little confused by your post. Is the 3.07 a swap out including the carrier?
IMHO - changing 4.27 is kinda out there... 4.27 is a great intermediate gear. :)
My goal is to stay ON the street--particularly in snow and ice. My last two 4x4s (non-Jeep) revved at 3000 rpm at 60 mph. With 4.27s my CJ5 would do the same.
With taller gearing I could keep the revs down.
I'm not a yj guy so I'm not sure if the yj had a high pinion 30 or not.
If it is a high pinion than no it won't work, if it's a low pinion 30 I THINK the gears should work.
One thing for sure is you will need new carriers for both the front and rear.
You can look up a gear set for the cj and the yj and see if it's the same part number to know for sure.
the carrier break for a Dana 44 is 3:73/3:92 and the 30 is 3:54/3:73
the carrier break for a D44 is 3:73/3:92 and the 30 is 3:54/3:73
OPPS :p I was thinking the AMC20 for some reason. Which the 3.07 and up use the same carrier. Sorry for the brain fart.
No. The YJ Dana 30 is a reverse cut (high pinion) gearset. All CJ Dana 30 's are standard cut.
No. The YJ D30 is a reverse cut (high pinion) gearset. All CJ D30's are standard cut.
Aha. I posted above before I saw your response. Okay, so I throw this onto the bad-idea pile and go to work on swapping on a newer windshield. (Meanwhile I'll keep an eye out for complete axles with 3.73s.) Thanks.
TCase Dana 20
