Build Thread CJ5 to CJ6 stretch project. PIC's
dsrt4
St Louis
73 cj5
Cool. That will be a nice Jeep when completed. I love the CJ6 style.
Welcome to the CJ5 .5 club.
Filthy garage And stretch. Ran out of gas right off the get go. Thankfully my old mig runs flux core wire really well.
I made covers for this area out of a second frame I had to give it somewhat of a stock appearance. I'll show those later.
Hope to get tub flopped up on it this week.
I use an ARC welder at home myself. It is slower and the welds are not as pretty but she gets the job done and I never worry about gas.
I used to use ARC for everything. I started getting a bit of shaky hand syndrome and went to MIG. I do miss ARC welding a bit. I was never good at vertical welding with it though.
Anyhow. Another update.
Got new front and rear stock shock towers on. And new brackets fabbed up in the intermediate style for the gas tank.
I ended up just getting another gas tank because of the varnish that was in mine even though I drained it.
Lots of old brackets cut off here and there on the frame from old builds. Hope to still get it out of the garage this weekend and pressure wash it and clean the rest of the garage out. Pics to come.
Thanks for watching my thread!
Just a quick note on varnish in a gas tank. Fill the tank with a 50/50 mix of water and pool muriatic acid. Let it sit for a few hours. Does wonders. At that point you can go ahead and use it or better yet the metal is etched nicely for the application of a tank lining material like they use on Harley Davidson tanks.
I wasn't much of a stick welder, then a Thermal Arc welder came my way. All welders are not the same any more. With a special starting circuit it is almost as easy as a MIG to start a weld. Then there is the advantage of being able to weld a less than perfect surface. Finally a good stick welder can really dig into thick metal and finally/finally you can always find the perfect rod for the kind of welding you are trying to do. My MIG sees 90% of my welding jobs, but for the big dirty jobs a stick is the only thing to use.
Sorry for the welding side track. I like the job on the frame. One thing did make me wonder though. When hot rod guys are working on a body, cutting the top for instance, to make sure everything stays straight they weld or tack in cross pieces. Yes, thing sheet metal isn't the same as a frame, but did you do something similar to the frame before cutting? If not, have you run into problems that wouldn't have happened if the stabilizers were in place?
The tank for this year was only $75 shipped so it just made more sense to go that route.
And yes I braced the two frame ends with 1X1 square tubing before I cut it . One raised and up and over the Transmission spanning the frame. The crossmember did the work on the bottom. The rear section of the frame simply had a 1X1 spanning the inside of the frame. The frame ends absolutely have to be braced before cutting. I've cut a few frames up before and they always spring sometimes a lot!. If you ever do something like this don't skimp. The 1X1 tubing only ran like $14..
After it is all said and done I'm about .062" off my original dimensions +20" so the bracing worked alright. You don't need much just something to hold it together.
If you don't use braces you better take a ton of measurements and have a bunch of straps and bottle jacks to reign it all back in..
cant wait to see this
How big a dip? You might be able to shrink the tubing. A talented metal man can do wonders with a little heat and a little water.
I'm not sure what you mean. Its a glass tub
The top rail on the drivers side has a tapered low spot then it tapers back up.
You can kinda see it in the pic on the drivers side top rail.
I'll probably split it under the lip, raise it up and clamp it with angle iron and then fill in the cut/gap with resin and mat. Some friends on another forum gave me that Idea.
I'm not looking to win any shows.
Misunderstanding, I thought you found a slight dig in the frame rail. Since your measurements are so close to your original dimensions I should have realized my mistake.
