cj5 with t18 rear dshaft
gliryan
- Duluth, MN
- '70 Postal DJ/CJ
'80 CJ5 Laredo w/ 304
'76 BMW 2002
I've just put a T-18 /Dana 20 into my early CJ5 . It's lifted on 4" yj leafs and overall pretty modified. Yesterday I tried to build my rear driveshaft, but couldn't for multiple reasons. First my 8.8 rear axle uses a bigger 1330 ujoint, need to get something to fix that. And second when my axle goes full droop the angle is ridiculous of the shaft, too much it seems for the joint. This may be because I don't have the correct ujoint in the back or the correct flange. I forgot to measure what the length was going to be…but somewhere around 17" I'd guess. Its got to be a little shorter than my T-90 /d18 to Dana 44 shaft. I think that was around 19".
My first question is how long is the stock driveshaft for a stock t18 cj5?
My second question is how tight is that t18/d20 tucked up in the belly? The difference in d18 to d20 cases is huge. The rear output is farther back and up quite a bit higher with the d20. Currently I've got that output right below the floor of the jeep, but the oil pan of the d20 on the low spot sits an inch or two below the frame already…
Any help or conversation appreciated!
Also I've got this all behind a GM 4.3l v6. I had to bend the t18 shifter back some even where it's currently sitting, so I'm inclined to think that my positioning is further forward than stock.
Here's the jeep I'm working with, I'll try to get driveshaft pics soon.
