CJ7 Frame Rot Repair
JLCBikes
Aberdeen, Maryalnd
1984 CJ7 Dana 44's , Nissan Sd33t diesel, T19 with Dana 300 transfer case (Drivetrain is from a 1980 Scout II.)
I'm struggling with my Mac here. I hope this post works.
I discovered, after dropping the fuel tank to check my fuel sender, which was fine but my voltage regulator for the fuel/temp gauge was not, that my frame rot that looked harmless from the wheel well, was actually a bit more advanced.
The hopefully attached images depict my efforts at removing the rust before I send it off to have the patch welded in.
https://www.facebook.com/media/set/?set=a.3523197200341.2132516.1284434328&type=1
Link still doesn't work.......
The code you tried to use is HTML code - the forums do not allow it.
PHP:
HTML:
[HTML][HTML][HTML]
<img src="http://p0.craigupload.comb251ca9c2739e1aee1e3271c1db09207/0/19013.jpg"/>
<img src="http://p0.craigupload.comb251ca9c2739e1aee1e3271c1db09207/0/19014.jpg"/>
<img src="http://p0.craigupload.comb251ca9c2739e1aee1e3271c1db09207/0/19015.jpg"/>
<img src="http://p0.craigupload.comb251ca9c2739e1aee1e3271c1db09207/0/19016.jpg"/>
<img src="http://p0.craigupload.comb251ca9c2739e1aee1e3271c1db09207/0/19017.jpg"/>
[/HTML][/HTML][/HTML]
You should only link to the images - use this post for information on the correct proceedures. -->> http://www.jeep-cj.com/forums/f16/how-attach-images-post-1270/
Think it only works for those of us with a facebook account... :cool:
Looks pretty deep there bud.
The last pic, was that of your repair "sleeve" ?
~ JR
Right , the sleeve fits over. I did some more grinding, cut off the muffler hanger . Now it's off to find a guy to weld for me.
