CJ7 Laredo Authentic Wheel Suggestions
sman26
NE
'86 CJ7
I have the original white with BF Goodrich M/S facing inward, but the chrome does look good with the letters out. Mine originally came with Goodyears but I didn't like them
It's a personal preference I believe
Thank you. I just want to make sure I find what people would consider the closest to authentic looking rims. Those on the sites I mentioned look pretty close but if other have found some that look a bit better or are cheaper...i would love to hear.
Thanks!
Okay...well, it will be impossible and a small fortune to find decent original rims for the CJ7 but if I wanted to get close, these are the 2 options I am finding.
Please let me know your thoughts of both. Which would be closest?
I'm starting to like these.
Cragar Nomad II
Cragar 3155755: Nomad II Wheel Size: 15" x 7" | JEGS
Then, there is the U.S. Wheel 75-5755 I pointed out earlier.
U.S. Wheel 75-5755: Chrome 8 Spoke Wheel (Series 75) Size: 15" x 7" | JEGS
I would like to order soon, please let me know.
Thanks.
Shawn
ps...there are these but I can't seem to find them anywhere.
Pro Comp Rock Crawler 83 Series.
Pro Comp Rock Crawler 83 Series - Chrome Steel Wheel 15x10 5x5.5 3.75" Backspaci - 4Mudders
They all look about the same to me. I would go with the Cragar because of the name.
They are all probably the closest you will get to OEM.
There will be a problem if you want to use OEM center caps.
You will have to drill the holes that are used to bolt the center caps to the wheel.
You had better confirm the center hole will fit over the front hub.;)
The Cragar I know does. The 2 others-Wouldn't bet on it.
