Build Thread Cj8 ground up rebuild
Fluids are full except for the Transmission need a kick down cable........
Walked back out to the shop 2 hours later to see a puddle of coolant on the ground. Look and find one of the lower bolts in the head has coolant dripping from it........ :banghead: :banghead:
Now I have to drain the coolant get that bolt out and figure out what the hell is wrong with it.......
Sent from my XT907 using Tapatalk 2
OK problem solved the bolt was stripped and not tight re tapped it and threw a longer bolt in it
Good to see you back at it. I'll have to swing by and check out the progress.
Its alive
At the shop getting exhaust
Putting the 42s on
gonna do the rest of the paint this weekend and finish the brakes
This thread was started in Feb of 2009. Congrats man , that Scrambler looks awesome. Now take it back to stock. :laugh:
It has only changed 10 times since then also.. thanks but its still not done. It will never be done there will always be something
Nobody cares if its "done" but you had to be grinning like a proud Pa Pa to mover her around under her own power. :chug:
:notworthy:
20 hours, 11 minutes, 36 seconds
