clutch link rod with bearings?
IOPort51
- Featured
- 5
- Media
- 458
- Garland Texas
- 1977 cj-5
2006 Toyota Tacoma
a few days ago someone had a source for a clutch rod with heim bearings on the ends to replace that retarded bent rod it came with. I built mine but have a mechanically challenged friend that is replacing his bellcrank assy and this would be a good move him.
If someone could remember where that came from I would greatly appriceate the link. As usual I will speak kindly of you to folks you don't know even when you are not around.
