Clutch linkage confusion 84 CJ7
Novak’s kit is flawless. Had it for five years, zero issues. If only they made a matching high quality master cylinder...
I do remember they offer two volume sizes to select pedal effort , f I am correct, or to match master cylinder, not sure.
No doubt! I was excited when i.pulled the slave from the box, loved the braided tube, then was a little disappointed when I unpackaged the master.
Works good though.
Sent from my Pixel 2 using Tapatalk
Well, I'll be starting from scratch. I will be doing the project on a CJ with a YJ tub.
I've never done this mod before, so if anyone has any tips or tricks for the pedal to master connection, that would be great too.
I can take photos of my setup if you like. Mines a CJ W/YJ Tub as well. With a TJ Soft Top!
Let me know what you want photos of.
I drilled the hole. Based it on the size of the eye on the master cylinder.
I had the same problem, I put in new linkage and the adjustable rod connected to the the lower arm was too long. If I flipped the rod with the long and short tabs so that the short tab was connected to the clutch peddle and the long tab to the clutch everything aligned up perfectly but extremely hard to push the clutch. Very little "engagement area" but clutch engagement feels solid and wont just fall out of gear. I guess you could say the clutch engaged and disengage in the top 10% of clutch peddle. Fip it around the way is should be according to the diagram and clutch peddle feels good but not sure that the clutch itself really engages correctly. Alignment of the lower rod from the clutch fork to short tab is wonky and while in 1st or 3rd while in gear but not under load from engine "coasting in gear" it will fall out of gear just under the weight of the shift lever. I was thinking about just switching to a hydraulic clutch but knowing someone else has the same problem makes me think that something else is wrong with the linkage.
Forgot to mention that I also had to shorten the adjustable link to the clutch fork by about 5/8".
With the 2 ends screwed all the way in it was still too long to allow the fork any free-play. There is a mile of adjustment in the link so no issue to take some off.
Replacing the whole assembly with a hydraulic clutch would have been a better idea but is it is done now.
Thanks again to all for the help.
Cleg
Used the existing pedal assembly. Used the washer to see where the hole would line up. Held it up to the pedal stop arm and centered it on the width of the clutch pedal arm. Turns out it located exactly where it needed to be.
Used a shoulder bolt and cut to length (on the bench with a nut on the bolt so you can fix the cut thread).
Thanks for all the pics. They are really gonna help.
No worries.
$35.00
  17.5%
