Clutch linkage woes
Clutch linkage woes
moranda
Nashville, TN
1985 Cj 7, 258, t5 tranny, dana 300, dana 30 front ox locker, amc 20 rear one piece axles ox locker, 4.56 gears,hydroboost brakes
Some of the Fords from the 50s had the same set up and i remember seeing some of them with brass. I don't know where they come from and have no idea of where anybody could get them but they must be out there somewhere.
i use alot of grease, the 4" lift really wears out one side of the bushing. i started carrying a spare set in the truck. very simple fix on the road side and off you go:D or power shift her home.
Two questions. Are you putting the retainer clips in place? Is the bellcrank level?
I did not install the bell crank/linkage kit last time. To my knowledge the retaining clips were in place and yes the bell cranck is level...... no body lift. AZ75CJ5 could you post a link of the kit you got? Guys, thanks for all your help
my suspension lift effects mine? dont know if you have any lift?
As of right now no suspension lift..... I do have a 4" lift not installed that I will slap on once a get a few more things for it. Also is there a better system than this? I have heard of people going to a hydraulic clutch not sure I want to do that because i might swap the tranny in the future.
this is the kit i keep in mine and it only seems to be one every time, seem to last 2 yrs or so, I think anything that retains the bushings/bellcrank is only gonna lead to the same.. been looking for something but no luck, which is why i just carry spares
Here's something to try. Turn your bell crank around. Mine was backwards, the arms are different. One is longer, one has a bend in it.
Been investigating this myself. Looks like the best/easiest route is to get the Novak Clutch Conversion Slave with mounting bracket. Says it fits AMC bellhousings so good chance your covered if you do a swap. Problem may be the cost at $176+. I look to do this but I'll probably wait until winter when I'm not driving it as much.
With flipping the bellcrank around which one goes to what? does the longer one go to the Transmission ?
I honestly don't remember. With the bell crank backwards the grease fitting was in the wrong position to the point of hitting the frame forcing it to pop off/out. The illustrations you can find in your service manuals show the proper placement. I found that mine was on backwards to clear the bell housing bracket, which turned out to be some PO modification. The stock bracket cleared up the problem for me.
There are 3 other options.
1) Hydraulic - Really like this conversion. Little more involved than the others, but worth it in my opinion. You said you don't want to yet because you may be swapping Transmission . Only thing you will have to change if you do is the slave mounting bracket (possibly) if it will not re-align with the new bell-housing. Possibly the rod between the slave and clutch fork would need to be adapted or replaced as well, but both are easy with fab skills.
2) there is always the cable system. This is less intrusive, but the cable can become very stiff over time, keeping it lubed will help, but the hydraulic is much smoother.
3) there is a advanced adapters kit with a chain and gear system i've seen one of our members did a write up on it somewhere... I will try to find it and post it.
I got tired of the stock system and went with Hydraulic.
I get my plastic bushings from the dealer the oem ones seem to hold up better.
The longer tab of the bellcrank, goes to the clutch pedal rod..
