Clutch questions
Gus
- Mountain Home Idaho
- 86 CJ7, 4.2L, T-5, Dana 300, Dana 30/Dana 44, Weber 34 DGEC
So this is the first clutch I am changing out. I have a couple of questions. To start off I had this thread going (http://www.jeep-cj.com/forums/f2/starter-noise-not-starting-10939/) and I came to the conclusion that I needed to change out the flywheel. I ordered a new flywheel and clutch assy, and got everything apart and found out that my engine is missing the alignment sleeves for the bell housing to the engine block, hence the bendix being off by a little.
1st Question: So is there a right way to put the clutch pad on?
2nd Question: Since I ordered a new flywheel and clutch assy, do I need to align the two in any specific manner?
3rd Question: Any other hints of advice or suggestions that I need to do while I have everything apart?
Thanks,
Gus
Thanks,
Gus
