Coolant Question
phinleft
- Baton Rouge, LA
- 78 CJ7, Amc 304 V8 - AMC 20, DANA 30, Quadratra Trac TH400, 35" Mickey Thompsons MTZPainted LSU Yellow/Gold. Modified with 4bl Edelbrock Carb.
I have finally got the engine running great! After enjoying the jeep last night, I got home, and discovered a coolant leak. If it isn't one thing, it will be another. It seems to be a cracked lower hose. I am going to replace it, and flush the radiator at the same time. The manual says to add 14.5 qt back. Do you all suggest a 50/50 mix for these old jeeps (7 coolant and 7 water)?
ate the intake gaskets out of both, and i had to put 3 water pumps on my truck, 1 radiator, and i've put 2 water pumps on the blazer, i cant even begin to count the number of thermostats i've put in both. you can't keep the rad. in the blazer from gettin clogged up with that brown
