cracked 304 head
OEM1984CJ7
Well, I was wrapping up on the project and finally got the carb installed and all the gauges to start the motor and set the rings. Put water in the radiator and BAM on the right side rear corner water dripping
A crack in the head near the last rear head bolt. Soooo disappointed. The heads were built and fluxed I was told so wonder what would cause the crack? Improper torque patterns or ft lbs?
I guess I need to find another set of heads and start over. Anyone know if you can re-use the valley pan? I ordered a top end gasket set today and new ARP head bolts from Jegs. Getting the materials ready.
It was looking so nice also:
