Crankshaft pulley
The CVF bolt-on solution is described for 1980 - 1990. Mine is a '76 so I'm not confident. I had not heard of March Performance, but those are also for the 4 hole pattern. Mine is similar to the CVF bolt-on 3 hole solution and currently lost in the mail.First, have you tried CVF or March for a pulley. I think they’ll be able to help too with the added groove you’re looking for.
Second, I don’t quite follow your question about belt routing for the ps pump. Are you wondering if it can run solely off the water pump pulley?
