crazy handling
crazy handling
Rope53
Texas
1981 cj7 gm 151 iron duke, sr4 tranny, dana 30 frt & amc 20 rear. stock no goodies!
1981 CJ7 Dana 30 , AMC20 . While in 4wd steering is almost uncontrollable on dry surface. Is this normal?
You should NEVER have your cj in 4 wheel drive on a dry surface, bad things can happen.
cj's have gear driven transfer cases and they bind up when either the front or rear can't slip some.
Thanks. The problem arises on patchy snow covered roads and I hit a dry spot. The spot is short, then back on snow. I'll stop looking for problems in the DT. Thanks again!
