Dana 20 Question
Duck
- Oregon
- 76 CJ5
258 6, Weber carb, 3spd w/Dana 30 front with Jeep disc brakes and cut down Scout II Dana 44 rear with 11" drums, front and rear geared 3.73,Dana 20 transfer, reverse shackle lift on 31x10.50.
I recently purchased a 76 CJ5 with 6cyl,3spd tran,Dana 20 transfer. While draining and replacing fluids in the Transmission and transfer (many threads on this site were very helpful, thank you All!!) I became a little confused about which is the fill plug on the Transfer Case . When I look up from behind the skid plate I see (on the drivers side) a bolt that appears to be a plug but is 6 sided. On the passenger side back of the case I see a square plug. My Haynes manual is unclear which is which. The 6 sided "plug" seems to be higher up so I could get more oil in, but I don't want to over fill. This is my first Jeep and my first post, any help would be appreciated.
