Dana 20 what goes in these 2 holes?
duke94
Ann Arbor, MI
77 CJ5, 83 CJ7
They are also used for 4 wheel drive indicator switchs/lights, they work similiar to the reverse light switch on your manual Transmission . If you look closely down each of the holes you will see a recessed area of the rail which is where the spring ball detent switch would ride.
I installed some pipe plugs. When I disassembled my Transfer Case the first time it was full of sand and dirt around the shift rails. Not good!
As purple said, I'd install something in there lightly to keep the dirt and grime out. (or water if you submarine race like me :) )
~ Jr
TCase Dana 20
