Dana 30 Cleanup
Eam94
1981 CJ7 Renegade with a Dana 30 front
I opened the center housing last week and my differential fluid was loaded with muddy fluid (looked like the worse case of this poopies I’ve seen) The axles tubes were also caked. So today I took a pressure washer and blew out the tubes, which worked out well. I also cleaned the inner differential with the pressure washer. Now I’ve got to replace not only my carrier bearing but also my pinion bearings. When I replace these bearing with oem style and shim everything just as it came out should I be ok? What’s the best way for a novice to resolve this? All the mud has pooled down behind my pinion gear and it’s pretty gritty when dry right now?
Thanks for the help
Thanks for the help
