dana 30 pinion bearing
bobt
pennsylvania
1978 CJ-5 258ci/T150-3spd
This might be a stupid question. Does the outer pinion bearing get greased?
No, the gear oil in the diff takes care of that, there are oil slingers (look like large washers) on the shaft that keep it oiled.
Thanks, When I took the axle apart, there was more mud and water in it than oil so I was unsure if it required grease or not.
Yea, that is fairly commom. I think when I got mine it had a rust stain across the ring gear as it sat so long and was full of water and :dung:.
When I regeared I ran my vent a lot higher in front and rear just in case I get into water situations, although not real common in AZ :D
TCase Dana 20
