Dana 300 adapter plate
DHugg
- Media
- 46
- Resources
- 1
- MS Gulf Coast
- '80 CJ7 304AMC crate with 8KMiles: MC2100 - AMC20 rear w/Superiors - Dana30 front - TF999 - Dana300TC - 35x12.5's - Tilt steer column - Flaming Rvr EZ-Steer Shaft - AGR Super Pump - AGR Super Box II - RockyRidge HD Brace - New home-designed digital TEMP - GAS - OILPR - CALIBRATE gauges.
As I broke the strain on the last top bolt (the one missing in one of the photos I was vectored to), I began to see txmsn fluid weeping out the hole in the tailstock of the Transmission where it connects to the Dana 300 ( see two attached jpgs).
That means to my simple mind a seal has leaked at the output end of the transmixer........ or is it a usual thing to see a drip every 4 seconds there?
I'm gonna go through Chilton's and Moses Ludel's books; think I saw something on this. but someone with more experience chime in, please.
BTW, Driver007, the single shifter shaft to my D300 IS threaded, not a smooth pass-through like yours. The speedo connector is different, and probably a bunch of other things. I'll try to post a list when I'm done.
The best way I found to get at the D300 top bolts was to remove the floor plate holding the rubber boot for the shifter.
