Dana 300 adapter plate
That is the simple and correct answer.:) The hole is there for just that purpose to indicate a bad seal. The seal is in the Transmission housing. When you split the t case from the Transmission you will see it.
I was working on a drag line in a coal mine when I had the same thing happen on a 1.5" diameter bolt. Worked on it all day could not budge it. A old timer came along drilled it out . The drilling released the preassure and it came out no problem. Some times tapping on them lightly and putting oil on them over a period of days works also. Every time you walk by tap on it lightly
Today's adventure was breaking loose the two hex set screws that grip the shifter arms. They are 3/16th ID and of course take a 3/16th hex wrench. Which I didn't have - dozen of the immediately smaller, 3 or 4 of the next up.
Went to Autozone, closest to me, and got an $8 long set just to cut up the 3/16th into two inch lengths with a Dremel 420 HD cutting wheel. I used a piece of wire inserted into the receiver of a 1/4 drive 3/16 socket for a binder and hammered the hex wrench section in. Used a 1/4 to 3/8 drive adapter so the long 3/8 extension wouldn't twist. The first, higher in the case, set screw came out OK. The second one was tighter than <-BAD WORD->'s Hat Band and split the 3/16 socket. I got a new socket, same treatment, and with much resistance to heavy ratchet pressure, the second one popped free.
I'm going to buy a 3/8 drive socket set of hex wrenches, good quality. Novak even warns about stripping the head way down inside the TCase. Too scary!
BTW - the speedo connector is a big hex-head requiring a quite large but thin-walled socket to remove it. I'll take a couple of photos tomorrow and post the socket size, in case someone else comes up with this job to do.
TCase Dana 20
