Dana 44 Swap Parts / Wagoneer / Scout Axles
aglinks
Flagstaff, AZ
‘83 CJ7, 4.8L Vortec, TF999, D300, AMC20, D30
Dana 44 Swap Parts
Front
PartQuantityLink or Part Number
Locker1https://www.desertrat.com/i-23365435-arb-air-locker-dana-44-30-spline-3-92-up.html#!
Gear Set1https://www.4wheelparts.com/p/motiv...atio-ring-and-pinion-d44-427/_/R-GGNW-D44-427
Gear Install Kit1https://www.summitracing.com/parts/mgr-ra28lrmkt/make/jeep/model/wagoneer/year/1975
Ball Joints2https://www.summitracing.com/parts/...dYrMqP-5d-zyP_Y12e5tKTaOzl1CrRqcaAln4EALw_wcB
Axle Swap Kit1https://www.ruffstuffspecialties.com/D44FSS.html
Leaf Springs2https://bds-suspension.com/product-display?sr=004351
Stub Shafts2https://www.summitracing.com/parts/aly-10128/make/international/model/scout-ii/year/1975
Rear
Yukon DuraGrip1https://www.summitracing.com/parts/yga-26027
Gear Install Kit1https://www.jegs.com/i/Motive-Gear/683/D44IK/10002/-1
Axle Swap Kit1https://www.ruffstuffspecialties.com/D44SS.html
Pinion Bearings1https://www.4wheelparts.com/p/dana-spicer-outer-pinion-bearing-kit-706030x/_/R-FSGR-706030X
https://www.4wheelparts.com/p/dana-spicer-inner-pinion-bearing-kit-706031x/_/R-FSGR-706031X
Steering and Suspension - Anything without a link is from https://www.wfoconcepts.com/
Steering Box1https://www.redheadsteeringgears.com/shop?year=1983&make=Jeep&model=CJ-7&options=24
Steering Shaft1https://www.quadratec.com/products/56113_910.htm
Jeep CJ 76'-86' Shackle Reversal Front Drop Box, Full Width 31.5" Spring Width, 2.5" Springs1WFO FBD-CJ-315
Jeep CJ Outboard Shackle Hanger Mount KIT, for 31.5" Springs1WFO SH-CJ-315-KIT
4" shackle kit with 9/16" holes (4 shackles)1WFO 6104-9-KIT
Bolts49/16" Bolt Kit G8 - 4.5"
Full High Steer Inverted T Kit, 1.5" DOM
w/ Weld In Bungs & Tierod/Draglink
Ends, NO PITMAN ARM
1WFO IT-15-KIT
M.O.R.E Steering Box Bracket (1.5" forward)1SB7686-1
YJ Large Leaf Spring Bushing Kit w/ 9/16" Sleeve, (4 bushings & 2 sleeves)4WFO 4200-9
Flat Adjustable Pitman Arm that has been reamed out to customer's measurements Draglink taper, bottom up, 5.25" long hole to hole1PM536FPA - REAMED
Hopefully this is easy enough to follow. If you have any questions, let me know. It all went together great and drives amazingly. I know everyone says to NOT use the CJ outers, but I did an it works well for me.
$20.00
  10.0%
