    Thank you for your support!
Dana 44s $125
Doesn't say what they are out of. Meaning how wide are they and how wide do you need?
Are the diffs on the correct side?
You will want disks sooner or later.
Lot of stuff to consider. . .
You can switch your disk brakes and steering knuckles from your Dana 30 over to the 44 so the front drums don't matter. If they are Scout axles then they have 30 splines shafts which are a good thing and a passenger side drop pumpkin.
they are out of a 73 jeep J300
They are full size than, about 65" wide.
Doesn't sound like the price is to bad, but plan on spending some more $$ rebuilding them and getting disks.
I'm sure you will want to narrow them some also.
Yea i think im just gonna pass and wait till I come by some from a scout or something
THANKS FOR THE REPLYS!
