dauntless cooling
Welcome fdny, my '67 Dauntless Buick 225 V6 has a shroud, I believe they all came off the line with a shroud.
Mine is the stock 17". Maybe you could build yourself one? Make a cardboard mock-up and use it for a pattern for sheet metal.
When I have an engine running too hot, usually the first thing I check would be the thermostat, then consider a professional cooling system flush. A shroud will help, but not a lot. Radiators can also be rebuilt.
Ditto on checking thermostat,belts,radiator flow,fan blades, and coolant mix ratio,etc.
For what it's worth there is a re-pop fan shroud for the 22" radiator.I have one on my '69 . Google partsdude4x4. Enjoy. Mike
$35.00
  17.5%
