Differential gear pattern?
Hedgehog
Always Off-Roading Jeeper
- Tucson/Marana Arizona
- -1975 Jeep CJ5, 360 V8, Headers, Duel Exhaust,T15 transmission, D-20 Transfer case, Twin Stick Conversion, Warn 8274 Winch
I do know a little, but far from all there is to know about installing a new Truetrac carrier and new gears. The pinion is set as it was VERY close to the old pinion gear as per the scribed numbers on the pinion face. Pinion preload seems good. The back lash is set to ~0.0055 (should be 0.010 and 0.004). But when it comes to the pattern I'm completely lost. After using snap line powdered chaulk mixed with white lithium to mix up a paste this is what I got:
Not as focused, but you can see the gears aren't too deep.
Some patterns have a nicely centered oval shaped swipe, at least one says this is a good hand turned pattern. I don't have a clue which is right.
