Clutch Do I have a clutch problem?
shooby
Lincoln Nebraska
1978 CJ5
360 V8, T18,D20,Teralows,D30 w/OX, AMC 20 w/OX, 1 piece Moser, 33"BFGs, Howell TBI, Mallory HEI
1978 CJ5 with V8 and T-18 Transmission . Hydraulic clutch. I see conflicting opinions on this but here goes:
When I try to put it in 1st or Reverse, most often I have to grind the gears. Yes, I put it in 2nd gear first and that is absolutely necessary but I still have to jam it to get it in reverse or 1st. Is this normal? I've been putting up with it for a few years now and after taking a better look at my clutch setup, I'm really wondering if there is something that needs fixin'.
Hey Shoobester...
What throw out bearing do you have?
What master and slave cylinder? (different / inappropriate bore diamaters can cause this)
What is the bearing to pressure plate gap?
Has this always been this way?
Hey belizian, is that the ledge where my front wheels came up and I had to back down and take the bypass?
That Bs the one. I had the perfect opening through the trees to watch. PM me your number if you want me to send the 2 pictures and 5 short videos
You can rule out the hydraulic mechanism if it consistently and correctly fully disengages the flywheel from the pressure plate. You should be able to confirm this by observing the clutch pedal point of engagement during departure from a full stop.
We know your first and reverse gears lack synchronized engagement so you must come to a full stop before engaging them. You might just be engaging first or reverse too fast after depressing the clutch pedal and not allowing the momentum on the Transmission input shaft to stop. Remember, this is a heavy duty truck transmission and is not designed for fast shifting. But it sure can transfer heavy amounts torque reliably. This might help you with your diagnostic departure point.
Shooby. This might be a silly question . But what is the engine idling at? High idle will cause grinding with 1st. and rev.
Didn’t mean to misinform or confuse anyone but I need to restate the following:
“You can rule out the hydraulic mechanism if it consistently and correctly fully disengages the flywheel from the pressure plate.”
I used pressure plate in lieu of clutch disc but surely you got my point.
I am confused. You are probably referring to the gap between the throwout bearing and the pressure plate fingers when the pedal is at full rest and a fully engaged clutch…
There needs to be a very small gap to avoid premature throwout bearing wear.
Don’t mean to drag on the subject but yes, there is one more important gap to be aware of and that is the clutch adjustment “air gap”. I wasn’t aware of it until I read some articles on clutches.
This gap is the amount of space that is created between the pressure plate friction surface and the clutch disc with the clutch pedal FULLY depressed against its stop point. If not adjusted properly, I can definitely see the clutch disc (which we know is engaged to the Transmission input shaft via the splines) never fully disengaging from the pressure plate resulting in gear grind and accelerated wear on the synchros. I will have to take a close look at my recently assembled new clutch components even though there are no symptoms.
usually idles at around 800 so I'm thinking thats about right.
I spent most of last year dealing with a bad AMC 304 and replacing it with a 360. Wish I would have put in a diaphragm pressure plate while I had it all apart.
Your gears are grinding for one reason only: The Transmission input shaft is still revving during gear engagement. What if you move the clutch disengagement point earlier on the pedal travel…
Was this ever resolved? Im having same issue on 1984 CJ7 AMC 258 i6 / 4.2l T-5 . The clutch is adjusted to full out position when clutch pressed (nearly no play in pedal and clutch arm goes all the way to the bell housing stop when depressed). Reverse grinds at a full stop, even after engagement and disengagement (still turning), and first and second gear can only be engaged if jeep is still rolling a little...once at a stop, wont go into gear without significant effort. I suspect tranny is still turning, but cant figure out why. No clue how old clutch is, 145k miles on odometer.
