Drive train
You will get quite an education from owning a Jeep CJ. There are different gear ratios available on the aftermarket for the Transfer Case and rear axles. It would require a different Transmission like a four speed to obtain a lower first gear though. Stick around as there is lots to learn, welcome to the forum.
:ww:
Please give us more Jeep info like tire size and such. Are you SURE the t'case is in low range?
Sounds like you have the T-150 3 speed tranny. The OEM t'case should be a model 20. Can you post(from under the jeep)pictures of the tranny & t'case so we can confirm this.
BTW: No need to use all 'caps', when post'n. ;)
