Drivetrain noise
Drivetrain noise
zacbkennedy
Lawrenceville, Ga
1973 jeep CJ5, inline 6, weber 2BBl, 33x12.50x15
Hey everyone I picked up an old jeep about 2 months ago. Started a complete rebuild, finally got her driving and road legal a couple days ago. Took her out yesterday and played with the 4 wheel drive. By the end of it the fan cut into the radiator and I ended with some form of clunking when I drive after bottoming out. I think it's the sliding yoke but I could be wrong. I took a picture of what I think it is not to sure if it's supposed to move as much as it is or if it's supposed to be fixed the the shaft going down to the from Transfer Case .
And this is what she looks like now
Bad u joint?
I'm hoping thats all it is! The end of the slip yolk the one in the first picture moves a little bit opposite end of u joint. Just not to sure what to look for or how to diagnose the problem
I would begin with checking that u-joint also as guy suggested, check the fit on that slip yoke as it could be worn out.
Pretty sure it's worn out because I can move it. So better off just replacing both u joint and slip yoke if I'm naming it correctly
So you said your fan went into the radiator that sounds like the motor and Transmission mounts are in real bad shape and that will put the drive line out of wack causing lots of problems. I would start there.
Haha my bad I mad it sound a lot more dramatic. I was working with a radiator who's brackets weren't in great shape nor the radiator itself. And the fan grazed the back of it and popped a hole in the back about the size and flow of a Capri sun straw
Ok then, if you grab the rear drive shaft where the slip joint is you should have no side to side movement. And have you pumped it full of grease?
I have, the rear has no movement but the slip yolk at the end closest to the back of the front drive shaft is the one with the movement one that has movement
