E-core coil power supply, when used with Duraspark moduale.
Goatboy4570
canada vancouver island
!983 CJ-7 258 locker moly axles 33's 4" lift MM hubs MSD/HEI 2100, 1990 YJ 258 31's.
78 Jimmy 357 Vortec 4 spd 205 lockers 33"s striped down, 63 F100 unicab 454 4spd RatRod, 87 S10, 88 S10 310V8, 87 Chev 3/4 ton, 80 Caprice Landu Coupe, 86 Monte 355 stock car, 1978 Monte 383 Vortec 4spd Slammed 10" rims Satin Black, 79 shovelhead OS chopper, 84 nighthawk, 88 CR500, 79xr500, 99 Susuki LTF500, 2010 Doudle bug 212 predetor. oya 2005 P71
No one addresses this question, not even team rush. After swapping in a E-coil whats the point of running a resistor wire?
The resistor wire is there to protect the old oil filled canister style coil from over heating and boiling maybe even starting a fire..
With a high efficiency e coil this is not an issue.
So why leave a power robbing resister in place to reduce coil output?
If i install a Hi 6s msd box which uses the duraspark mod as a trigger along with a e coil they are very specific that the resister has to be by-passed.
Is anybody running with this wire by-passed?
I was on the Pantera site, they run ford motors and duraspark.
So in cali were everything has to run lean, and lean is harder to lite off, the ignition has to be hotter.
That go's for duraspark too. so ford makes a box for Cali #D7a3-12199 uses a low resistance coil and no resister wire, red wire bushings.
