Early CJ-5 clutch linkage retrofit
BajaEdition
Resident 'Old' Jeep Shaman
Featured
Riverside Ca
67 cj5,225 Dauntless, D30,chrome molies, detroit, D44, full floating detroit, custom steering, disc all the way around,2 inch lift on 31s, armored up
70 cj6 4 inch lift
Nice write up!
Thanks for putting together such a detailed post! :)
Hey baja, great writeup. I have been uphappy with my clutch linkage for about 20 years (various CJ's from 1973-1977). I tried to find your kit, is this it?
(P/N 716639) JEEP CLUTCH CONTROL 1972-85 | Engine & Transmission Conversion Adapters - Advance Adapters
$220 seems like a chunk of change, and the picture looks quite complicated. Is this what you used? If not, how about a link? How is is working out for you now that you have some miles on it?
I heard about a cable linkage that I was interested in. Do you know anything about that?
thanx
dave
that is a related item, it appears it has the same roller chain of the item I purchased.
ok, I used mine on a 67, there is a big difference between my Jeep and yours and that is all Jeeps 71 and earlier, the pedals are not hung off the firewall, but go through the floor and work off the frame. Now if your Jeep is a 69 or earlier the unit I got works, all 70s and 71s have a cable clutch linkage that no one makes a kit for so you are screwed.
Your Jeep, having the pedals on the firewall, needs a linkage down to the underside of the cab to get the chain system to work, so I see they have made one to use with that chain drive. I think that was a killer idea as that chain drive is the cat's meow.
How do I like it, WOW, what can I say, the first time i pressed it in there was a HUGE difference in the response of the clutch, IT was smooth, and used about 1/3 the effort to do. I since have replaced the T-86 with a T-14 and I did not have to do all the normal clutch linkage adaption that you would have to do as the entire system is that chain drive, so it made the swap super simple. I actually had a Jeep shop install the new Tranny/tcase system and source the driveshafts and install because I was in a hurry and needed the jeep in 2 weeks for an event and their estimate of labor was more than the actual bill. Seems not having to relocate the linkage and just rehook up the chain drive I had installed saved me 2 hours labor.
I am extremely satisfied with unit, I have wheeled it 2 times, yesterday I got under there and sprayed motorcycle chain lube on it and figure that will be good for quite a while.
Would I recommend the unit you are looking at, Oh Yea, I went into mine site unseen and love it, I think the quality of the product is great. I would imagine from the past products I have gotten from AA that the unit you are looking at would be top notch.
One more thought, they system I replaced was 40 years old, worn and problematic from the factory, AA offered a nice solution. I think all clutch linkages I have ever used besides Hydraulics are that way, It is not a Hydraulic clutch, but it is a very well thought out system that is about 90% easier to hook up. My only thought would be go Hydraulic if you are worried about their linkage between the pedals and the chain drive.
Hope this helps.
Thanx, I was wondering about the chain getting clogged up with mud, but I guess that's not a big deal.
220.00 is quite a bit of money to replace something that works, but as I said, it is a pain. On occasion, I have had the thing pop out while off roading.
I may just do it.
I went hydrolic with my clutch in a CJ3b was a lot easier to set up and costs about the same
I went hydrolic with my clutch in a cj3b was a lot easier to set up and costs about the same
I thought this would be much tougher to set up. Do you have a link to something so I could see what I would have to do and pay?
thanx
Hate to revive the thread, but I saw your awesome write-up and am thinking about doing it myself to my '69 CJ5 (V6).
Question: I'm having to fix my clutch because the bracket on the frame where the bellcrank attaches broke in half. Do I need that bracket for this kit, or does it even attach to the frame (on the back end of the assembly)?
Also, my clutch pedal is not popping up after being depressed. However, we couldn't find a spring anywhere, and I'm not sure if it even uses one. Will replacing that bracket or installing the chain assembly fix this, or do I have another problem?
New to the forum here, and thanks in advance for the help.
Check out this link. http://members.cox.net/a74cj6/08Clutch.htm
Mine used to pop off. Fixed that. And then the frame twisting started popping off. Hydraulic fixed that. Love it. With used parts, it ran about $70.
Nice write up Baja!
I just got done installing the Advanced Adapter chutch system and it was a snap. Saying that because I installed it with the body off. The cross bar or tube that connects between the Transfer Case and the frame is not used. As for the bellcrank I'm not sure of what your talking about. As soon as some one will show me how to post pic's on this site I will send them on to you showing the install from the top of the frame. Good Luck
May ways... Check this out: http://www.jeep-cj.com/forums/f16/how-attach-images-post-1270/
I used Hyme-joints (spelling) and original linkage design. has been working alright so far, though at extreme flex it does become a little "spongy"... One day I will either go to this or Hydraulic.
~ JR
This is great. I have a 1981 CJ5 6 cyl and have not had any luck finding one of these from advance adapters web site. does one exist for what I have that you are aware of? thanks in advance for all the help.
Your 81 uses a different style clutch linkage. Its a bushing and bellcrank design. If you want to upgrade you need something like this:
SpeedDirect - CLUTCH LINKAGE; 76-86 CJ JEEP
