EGR and O2 sensors
EGR and O2 sensors
dburden
Gold Canyon, AZ
86 cj7, 4.2 Liter 4 spd, Dana 30 and Dana 44, Weber 32-36, 33X 12.5, smog removed
I have removed the smog equip from my CJ7 '86... thu still have the egr and o2 sensor.
Are there any issues with installing a plate on the egr and a bolt in the o2 sensor hole?
I have been experiencing intermittent loss of power at highway speed and was told that it might be loss of vacuum from the egr.
Thank you for your imput.
I would suggest hooking back up the egr, as it will make your cylinders and valves burn cooler. The o2 sensor will serve as a good hole plug as it is.
I agree the egr doesn't reduce power and does help the engine.
so you don't think that the egr would be a vacuum leak source? I can sure hook it back up
Have you done the Nutter Bypass? If not by just unhooking stuff like the O2 sensor it's going to make it run bad.
A worn out egr could be a source of a vacumn leak, and if you do not have the Nutter by pass, I don't think the engine will run at all. I am sure you have pulled the computer out.
    Best for votes
    on specific items
