EGR Removal?
EGR Removal?
Reddrig
Ca
1972 Jeep CJ5 304 T15 Dana 20 Holly Carb
Dana 44 rear
Dana 30 front 4.27 stock gears
Front and rear power disc brakes
35" Mickey Thompson tires with Mickey Thompson 17" wheels
Rhino lined tub with custom tool box
Rugged Ridge ORV 4" lift, 1.5 BL
Ditching the egr is not exactly a good idea, since it will help keep the cumbustion chamber temps down.
So if I keep the EGR, what can I do so I don't need to run a line into my valve cover? Can I route that line directly into the PCV valve inlet that is currently blocked off?
The egr works from a ported vacumn source thru an egr cto switch, since the egr operation is not needed on a cold engine. There is a layout of one on a AMC 304 in the Haynes Jeep CJ manual page 6-8.
Ok, I'm ok with keeping the EGR valve, can someone tell me if I still need to run the line to my valve cover. I'm installing new valve covers and don't want to drill a hole in them. Is there another location this hose can go?
My '75 AMC 304 didn't have any holes in the valve covers, neither does my '82 360. I don't know if that helps.
Would it be a problem to just plug the hose to the valve cove? I'm guessing no.
I pulled the EGR then tapped each hole and installed a pair of those pretty allen head pipe plugs. Problem solved. You could also splurge for an aftermarket intake with EGR delete.
Do you mind posting a picture of you setup?
Sure, just got back in town tonight and will take a picture in the morning.
    Best for votes
    on specific items
