Electric Fan HELP!!!!
dave pam
- CT
- 2002 Jeep Sahara, dana 30 F. dana 35 R. stock tranny, 4.0 automatic, stock transfer case.
So I was out last weekend in 95deg temp wheeling and decided to upgrade to an electric fan to keep the rig cooler when crawling over rocks in the sun. So I bought a 1400cfm fan and auto sensor t-stat, all hooked up and works BUT when I tested it in a parking lot (creaping along in the sun) the temp rose to 246deg (fan running) and did not cool
, I then hit a tree covered dirt road and creaped along again (temp stayed at 246deg) then I ran it home (hitting 35 to 40 mph) and when I got home it was at 458deg.
What the
is going on?? do I need a higher cfm fan?
O and there is an A/C cooling radiator and small trany coil as well.
What the
is going on?? do I need a higher cfm fan?O and there is an A/C cooling radiator and small trany coil as well.
