Electric fans and alternaters
IOPort51
- Featured
- 5
- Media
- 458
- Garland Texas
- 1977 cj-5
2006 Toyota Tacoma
First things first, HAPPY NEW YEAR everybody!!
I went to the pull your part grave yard yesterday. My kid brother came down from the country we sent the girls off to "shop" and made a day of it. wasn't really looking for anything special but I had not been in a few months and there is this huge new crop of "cash for clunker" parts.
As an added bonus I found , when we arrived, it was a half price day! I guess this only happens once or twice a year.
I picked up a Taurus electric fan, an SI 12 GM alternator that I am hoping id a 95 amp and four relays that I am hoping are at least 40 amp with water resistant sockets and 10 gauge wiring. All this for $45. not bad for impulse buying.
Now for the questions these parts have raised, The fan is three wire color coded as solid black, black with green stripe and black with red stripe, the black with red stripe has a "splice" just up stream from the connector that is heat shrink wrapped that may be a fuse link(?). I would think that the motor would have a common and a high and low. When I apply power to pairs of wires the speed is different but any combination of wire to power and ground runs the motor common/ high, common /low and high / low. The question is which wire is which?? I am not reading an appreciable resistance difference between pairs. If I was to guess I would say black was common , black with green was low and black with red was high. Does any body have access to a ford schematic that would confirm this?? I am not really planning on using the two speed on the CJ, but it may not be a good Idea to wire high to low, for any length of time. I am thinking I would like to do this to the J-10 some lace down the road and use high for the A/C.
Question two; The alternator I bought has two wires on the plug and one to the battery. I removed it from a early 90's caddy, there were also SI12's that had one wire and the power wire. I know that one of these wires comes from ignition but what is the other? I have been looking for a site for alternator wiring unsuccessfully, If you have one It would be appreciated.
