Engine Engine mounts location
- Featured
- 1
- Media
- 188
- Solutions
- 11
- Thurmont MD
- 85 CJ7 4.2L 258 .040 over, T-5 trans, dana 300, dana 30 front 3.23 and lock right locker, rear amc 20 3.23 one piece axle shafts traclock
79 CJ7 304, th400 auto borgwarner 1389?? qudratrac stock rest unknown.
89 YJ 4.2L 258, AX-15 5spd, NP231, dana 30 front, dana 35 rear with posi, gears unknown
92 YJ 4.0, AX-15 5spd, np231, dana 30 front, dana 35 rear.
I need some pictures of stock AMC 258 i6 / 4.2l inline 6 engine mounts and there location. (Both sides) Both frame mounts and engine mounts.
The issue is the motor is sitting to far forward (about fist width off the firewall) so I need to see what holes in the frame a factory setup is (mine has 6 holes in the frame and is currently in the forward 4 most) and the engine side in case they got swapped left to right in the past at some point.
Otherwise everything is factory including T-5 Transmission Dana 300 and drive shafts etc
