Engine Swap Question
Gsmithl10
- Sharpsburg, Georgia
- 86 CJ,Dana 35, AMC 20, 258 I6, T176, Dana300.
Thanks for the link. Told me everything I needed to know. I think I'm gonna put a 4.0 head on the I6 and change the gears.
I've got an AMC 20 in the back and Dana in the front. How do you tell the difference in carriers? Any gear recommendations? I'm running 35s. It will mostly see asphault but I do want a capible off road machine.
Personally Id recommend 4.56 gears for 35 in tires in your scenario. I mentioned the small carriers due to the year of your Cj. Your Cj would be a dog with 35 in tires and the 2.72 gears alot came with stock. Maybe this is why you were considering a V-8 swap?
If you want to check what ratio you have heres how.
Jack up the rear of the Jeep and put it on jackstands. Put a mark ( piece of tape , chalk ) and rotate the tire 1 full rotation if you have a locker , 2 full rotations if you dont. While your rotating the tire the correct amount of times count the revolutions of the driveshaft. This will give you the gear ratio.
Example: locker 1 full turn of the tire nets 4 turns of the drive shaft. Your ratio is 4.10.
I've got 4.27 gears in my CJ5 that I run with either a set of 15/35-15 TSLs or old 36 Buckshot Mudders. Gearing is PERFECT with a good running V8 and my trans/T-case combo and doesn't cause excessively high rpms out on the highway. Lot of factors involved with picking the correct gears - suggest that you figure out what motor you are going to use first, then tire size, followed by trans/t-case gearing, and use before settling in on axle gears. You really want to get it right the first time.
Alright, I've decided to keep the I6. Gonna run the bigger 4.0 head from odessa with a comp cam part # 68-231-4. Lift is int 463/ 485 exaust. Bore the cylinders out (just what is needed) and put on the 4.0 header. My question is... Will my weber 32/36 and stock intake work for the time being until I get the funds for a clifford intake and bigger carb. Not gonna get FI trying to keep it as simple as possible.
back on your nice rebuild. I have that same carb on my jeep and it doesn't like hills. I always stall on the climb and it's not fun rolling back down steep inclines with little ones in the back. I did some research and found this is a true issue for the Weber. There is a piss poor solution and that is to turn your carb around 180 degrees. The problem doesn't go away completely, it just makes it stall coming down angle vs on the climb. So the thought behind that idea is you can clutch brake and start your engine as you decent down the hill vs stalling on the climb and getting screwed.We use essential cookies to make this site work, and optional cookies to enhance your experience.
