Exhaust Manifold & Header Bolts/Washers
Tin Medic
Ft. Carson
85 CJ-7 Renegade:
Fuel Injected 4.2L I6/T5/D300
D30 with ARB Air Locker, AMC 20 w/Posi
Warn 8000 LB winch
VIAIR Onboard Air System
33x12.5x15 Goodyear MT/R's
Kenwood head Unit
Hella E-Code Lights
What is everyone using for bolts and washers for the exhaust? When I removed the intake & exhaust manifolds I found multiple types of washers in various amounts on various bolts and I am going to put new stuff on. I am looking at the Stage 8 setup and was curious what you guys are using.
I made about half of mine to cover the 4.0 intake and used the heavy cup washers that were there originally.
I also used studs rather than bolts, I think it is easier to line everything up. I also like to assemble head and manifolds before putting the head on the block. There are a couple of nuts/bolts that are impossible to torque otherwise.:D
Anyone know the bolt size and thread for the AMC 258 i6 / 4.2l ?
They are two different sizes on my 1980. One is 5/16ths? (1/2" wrench) and the other is whatever uses a 9/16" wrench.
Can't help you on lengths, mine is back together and staying that way if I can help it...:D
Studs are the way to go. They hold the gasket while you install the manifolds. I got a package from O'rielly that had an assortment.
Do you remember what size the studs were? I think they should be 3/8 16 but I cant remember.
$20.00
  10.0%
