External to Internal Hubs
ColeTrickle
Fort Worth
'83 CJ7 Laredo 258/T5/D300
'80 J10 Honcho 360/727/NP208,
'79 J10 Honcho 360/TH400/QT,
'75 J20 "Workhorse" 360/T18/D20
Has anyone done this?
My Cj still has the stock external plastic hubs on the rotors. I plan on going through them in the next week to check the bearings and seals.
Would anyone know what vehicle I need to look for to have a replacement and accept the same tolerances for the spindles?
Thanks for the help!:chug:
I have converted to internals using the Warn Kit #37132, for the Jeep CJ, this kit uses the oem spindles. A major advantage is that the hublocks will not come loose like the oem ones will even with front lockers. The big disadvantage is that they cost a fortune.
I'm running F150 hubs/discs with Chevy spindles on a Dana 44 . Set up will work on a Dana 30 as well. Many articles out there as it is a bolt-up.
I kept destroying hubs with 6 bolts. I tried studs and locktite and helicoils with studs.
Not a problem since the conversion. :D
Cool. Thanks 73.
I didn't want to pay the big $$$ that the Warn kit sales.
I'll do more research.
Get a set of good hubs like Mile Marker, and use threaded studs.
I run a DL in my front and have no hub loosing issues.
BTW-The OEN Warn hub on our CJs is a junk zinc casting.
    Best for votes
    on specific items
