Factory 304 V8 frame mount question
OEM1984CJ7
E. Tenn
1984 CJ7 258 w/T176
Are you saying you plan to use one of the AMC 258 i6 / 4.2l brackets on one side and a replacement one on the other? Not sure if I'm understanding correctly.
I have the smaller AMC 304 mount; guess I tossed the bigger one on accident.
If you want I can compare measurements with you.
Yes, I will use the existing AMC 258 i6 / 4.2l drivers side bracket (small one in first picture) and replace the passenger side with bracket in second picture.
Is this the same setup as you have jason?
No, I put a Ford V8 in mine so i used some aftermarket ones.
Im guessing you read somewhere that the drivers side one is the same for AMC 258 i6 / 4.2l and AMC 304 ?
Sorry I cant remember which way they go but yes one of the AMC 258 i6 / 4.2l mounts is the same as the V-8 mount so all you need to do is replace the other side with the proper one. I do believe the driver side is the right one.
