Build Thread Father/Son Project in Orlando
- Orlando, FL
- 1985 CJ7, AMC 360, lunati cam, AX15, Affordable Fuel Injection, edelbrock performer manifold, 21 gallon fuel tank, Old Man Emu 2.5 inch lift, 1 inch body lift, tie rod flip, HMMWV H1 steering box, rear disc brake conversion, Dana 44 rear, YJ to CJ tub conversion, still working on 33 inch tires, Metallic dark blue paint.
Scrambler Project, cosmetically taking it back to the 80's- 1984 Scrambler, Laredo. 258cc, Holley Sniper EFI, 30in tires on Laredo polished wheels, Dana 44 rear, OME 2.5 YJ springs/lift, HMMWV steering box
Previously owned cj 7, 1979, Renegade, 258 and a '89 wrangler
Yup, your pic is right. Here a couple perches I found, there are some Co. out there that sell fab parts that might be cheaper or more heavy duty but make sure they are for the wider 2" springs. When you weld them on you can adjust your axle pinion angle at the same time so no wedges needed.
Jeep 4x4 Center Search Results
Search Results by 4 Wheel Parts
The Shocks are usually mounted tube down but almost all newer shocks can be mounted either way, just check with the mfr. to be sure.
Do I need to change the perches in the rear also?.... how do I know what angle to weld them on so that I don't need shims? I know I have read about 4 degrees, but that's 4 degrees so that the U joint that connects to the drive shaft goes upward correct?
