Body Firewall Hole
Body Firewall Hole
John Casey
Lifetime Supporter
Upper Kingsclear NB
85 CJ7, 258, T176, D300, AMC20
Solution
It's for a clutch master cylinder if your CJ had an original hydraulic clutch system. Looks like yours did but was converted to a manual system or someone put a hydraulic system on it at one time.
It was used on factory 150 cid four cylinder CJs. What does your VIN say for your factory engine? Has it been swapped? (Link)-> CJ VIN Decoder -<
Master cylinder:
Slave cylinder:
Firewall location:
Solution
Ah, thanks for that.
Someone must have tried a hydraulic clutch at some point since mine is a C-engine AMC 258 i6 / 4.2l .
I suppose the other possibility is that it's not the original tub tub.
Looks like a great protected place to run wires out as needed... :chug:
that’d be a great place to run wires! Is that grommet specially made for that punch out, or is it a similar size to a commone grommet?
Yup. The punch out hasn’t been removed on my jeep. That grommet just looked perfectly sized for the hole.
