First Time on the Interstate
Well... I finally have my 74 CJ5 in pretty good running condition... It was 4 months of fun that included a lot of wrench time, welding, painting, fabrication, and modification (of course, some cussing as well)...
So, I take it out on the open interstate today, 40 miles round trip, to get some gas in the Jeep and the gas cans...
While at the gas station, when I pulled off the gas cap, there was a big out rush of air from the tank... Like the tank is not being vented properly... Even now, sitting in the garage (an hour later), I can hear the gas tank being vented slowly... I do not think this is normal... What should be the normal venting of the gas tank? Should you hear the venting while the gas tank is cooling down after driving?
Another thing I noticed, while sitting in the garage, is a small oil drip from the Transfer Case ... I believe the output shaft (drive shaft) seal is leaking... How hard is it to change the seal?
And lastly, I clocked my Jeep while going down the road... I used an App on my phone that connects by GPS in order to give me speed... I have used the App in my other vehicles to verify its accuracy... It is pretty accurate (within 1 mph)... It appears that I am going to have to change the speedo gear in my Transfer Case (Jeep was lifted by previous owner with 33's on it)... If I know the Jeeps speedometer reading and the true speed of the Jeep by GPS, can I calculate the number of tooth gear I would need for the speedo?
Thanks for the help guys/gals!!!
