Fitting 43's on cj5
Sorry i didnt understand your question
I believe he was asking that when the axle droops and then compresses again,what will keep the shackle from folding in under the jeep instead of out ?? did you move the front spring hanger on the rear spring back 2 inches ??
Looks good... you may want to turn that rear axle over before you weld it up :D.
Do you plan on cutting the body in the rear to clear those tires?
Lol...
Yes i will ve cutting the rear... The tires i am going to use are 42.5x13.5
Sent from my iPhone 5 using Tapatalk 2
Lol...
You lied. You promised 43s. :D
The 1/4 ton yj springs won't last long with your setup. I went with stock 1/2 ton wagon springs on my 105WB CJ5 . Even with stock height springs I'm too tall at 22" clearance at the skid and that's with tires 3" smaller then yours.
Sorry but the 43s where to big...lol
The 1/4 ton yj springs won't last long with your setup. I went with stock 1/2 ton wagon springs on my 105WB CJ5. Even with stock height springs I'm too tall at 22" clearance at the skid and that's with tires 3" smaller then yours.
What makes you think it wont last?
I currently run 38.5 Boggers, and I've had 40x17 Ground Hawgs under my CJ7 with stock springs in the back. I've had ladder bars the whole time, mind you, but still was using stock springs.
Granted, this was on the back. On the front I have modified 73-87 Chevy 4" springs. Once they settled in, they ride at a stock-ish arch for CJ springs.
Panamacj5 - I thought the question was easy enough to understand, if you missed what I meant, then that is answer enough. Good luck with your project and have fun now.
I feel the yj springs are ok for 44s axles and 37s and down tires. When you start running tons and larger tires the 1/4 springs are not stout enough. A friend ran yj springs with tons and 39s and they didn't last him a year. If you must run yj springs mix in some 1/2 ton leafs.
Hope this helps.
Thanks fot the advise i will swap a couple of 1/2 ton leafs
I'm running stock yj springs front and back on a CJ7 with 350,1 tons and 37 inch military wranglers
This is a cj7 with yjs leafs springs tons and 42s they are holding fine
You don't say how long they have been on, how often he wheels, or how hard? I can tell you from first hand account one of my friends cracked a leaf within a year the rest were toast, another friend with an 83" wb CJ5 36" Q's replaces bump stops every other wheeling event.
This is only what I've seen first hand, you or others may have different results depending where and how you wheel.
Everyone likes mud in the beginning....:D
Those Youtube clips look like a lot of fun! Although guys my age don't sit on the hood of a CJ or any other vehicle with a cable out.
I guess it all depends where you live at...so i guess yjs leaf didnt work because u are TOO HARDCORE
More than likely he was referring to playing in the mud causing more breakage than playing in the rocks.
Play nice everyone. :)
