Fly Wheel for a 304
Fly Wheel for a 304
GPER
Kettering, Ohio
79 CJ-7
I have a 79 CJ_7 with the AMC 258 i6 / 4.2l motor and T-150 trany. I picked up a 79 AMC 304 the other day and it doesn't have a fly wheel. Will the 258 flywheel work or do I need to find one for the 304???? There is a swap meet next weekend and any leads to one will be helpful, thanks.
I have a 79 CJ_7 with the 258 motor and T-150 trany. I picked up a 79 304 the other day and it doesn't have a fly wheel. Will the 258 flywheel work or do I need to find one for the 304???? There is a swap meet next weekend and any leads to one will be helpful, thanks.
Sorry but the AMC 258 i6 / 4.2l and the AMC 304 flywheels are not interchangeable
AMC V8 engines are externally balanced and are engine specific. All AMC V8's have their own flywheel. I.E. a 360 flywheel won't work on a AMC 304 , the same with a 401. Very technically each flywheel should be balance to each individual engine. I can see it now, Why did he say that and where is the technical article? When I needed a flywheel for my 360 two different shops, Don's Hot Rod and another I can't remember the name of said essentially the same thing, "To do it right you need to buy a blank and have a machine shop balance it to your engine." The very thought of how much that would cost scared me to death. I got mine from Rob at Willys Works, it works and I'm happy with it.
AMC V8 engines are externally balanced and are engine specific. All AMC V8's have their own flywheel. I.E. a 360 flywheel won't work on a 304, the same with a 401. Very technically each flywheel should be balance to each individual engine. I can see it now, Why did he say that and where is the technical article? When I needed a flywheel for my 360 two different shops, Don's Hot Rod and another I can't remember the name of said essentially the same thing, "To do it right you need to buy a blank and have a machine shop balance it to your engine." The very thought of how much that would cost scared me to death. I got mine from Rob at Willys Works, it works and I'm happy with it.
Thats a machinist for you. If you have a stock engine you will be fine with a stock flywheel :chug:
One of these days I will get to build my 360 the way I want to and it will be balanced with the flywheel and clutch :chug: just dont hold your breath waiting on me tho
I believe I have a AMC 304 flywheel, I'll check when I get home.
