FLywheel for an AMC 360
Hedgehog
Always Off-Roading Jeeper
- Tucson/Marana Arizona
- -1975 Jeep CJ5, 360 V8, Headers, Duel Exhaust,T15 transmission, D-20 Transfer case, Twin Stick Conversion, Warn 8274 Winch
For starters, I am completely aware that AMC V8 engine are externally balanced in the flywheel. AMC flywheels are specific to the engine displacement.
The meat of the post and question would be. When does a flywheel need replacement?
Going back in time. A couple years ago a tired old 304 was removed and an AMC 360 installed in my CJ. The 360 needed a flywheel so I went to Rob at Willys Works and bought a used one from him. Rob is very careful with his used parts so I trusted his opinion. The surface of the flywheel was somewhat "torn" or "ripped" in places. Even after it was resurfaced the "torn" areas were still there.
The flywheel was installed. For those of you who wonder how the thing was aligned properly. Flywheels are drilled in such a way that they can only go on in one orientation. A mistake simply CAN'T be made. The threads were cleaned, new bolts were installed with blue lock-tite, everything was torqued down.
A new clutch and all that implies was installed. Pilot bearing, clutch disk, diaphragm pressure plate, through out bearing. Even new fork pivot ball and spring.
The T-15 and all that implies were installed. And the clutch chatters, it has driven me nuts.
Now, a T-18 will be replacing the T-15. Yes, I know what is going to be needed for the install, even new drive shafts.
So, here's the meat of the question. Can the old flywheel be reconditioned. Meaning, can the "torn" areas be welded and the surface be reground. OR when do you know when a flywheel needs replacement? Do you know of a good quality replacement?
