Frame repair
surfbum
- Media
- 1
- South Jersey (yea, someone has to)
- 79 CJ7... 258 motor... T-18 trans... Dana 20 case... Dana 30 w/ lockrite... AMC 20 w/ detroit and 1 piece axles.
Here are some pics of this weekends frame work on my '79 CJ7 . I kept whaling on it with the BIG thumper until I found where I had good metal.... and then went to work with the grinder and the heavy wire wheel. After coating it with POR 15 and then primer, the 1/4 plates were bolted into place and then stich welded. I didn't have time to take any pics last night after the application on 3 cans of rust killing primer and 2 more of rustoleum flat black, but suffice to say, she looks better. I took a pic of the back too. Note the "access holes" the PO made to get to the body mounts(I guess). Time for more aluminum plate. LOL Tonight we're gonna tackle the gas tank skidplate and patch that up with some galvanized.
I'll post a better pic of her when I get done installing the new stainless brake lines, wheel cylinders and brakes; and can get it outside. Oh yea, Thanks to this site, I was able to get the D@#M brake drums off
. I don't remember my '86 having those stainless screws holding the drum to the hub???... but that was many years and beers age.
On another note, The springs are 5 leafs with red eye bushings (rancho maybe) They are tapered on the ends with antifriction pads but have no degree shim. Would these be stock??? The shackles are not stock. I believe they are 3/4 " lift shackles and it looks like it has a 1" body lift. The Jeep sits on 31" tires now with MAYBE room for 32's. Does this sound right? I figured with stock springs, the 1" body and the 3/4" shackles, there should be more clearence than that???? Unless the springs are a stock replacement. I can take a pic of them if it would help.
Again, thanks for all your time
Mark
Mark
ed at the 'access' holes! That's just not right!!!
