Suspension Front Drive Shaft Clearance
TBplayer
Donator
Featured
Virginia
80 CJ7 304
Will a 2-2.5” lift work with a Waldron CJ7 y pipe without having clearance issues with the front drive shaft? It definitely will not work with the 4” lift that I have currently. Are stock leafs my only option?
A very confusing post.
I know the a Waldron brand name is from Advance Drive line in Orlando fl.
What are you asking? Is it that you have a working system with 1.5" lift and if you go to 4" will it be ok? Yes, when triangulated it is only a insignificant yoke change of about 1/2".
I don't understand what the ask about any pipe. The normal y pipe would be an exhaust behind the engine, not in front.
Well s*** fire. Definitely not my local Waldrons... This is so much I learn from the forums.
$45.00
  22.5%
