Front tires won't grab
slans31
- Media
- 3
- Burkburnett,Texas (for now)
- All ford, except my 1978 CJ5 (well it has some Ford in it), 304ci, Holley carb, Quiet exhaust (sleeper), Dana C300-15-2 Transfercase, 4 speed manual trans (C-2604203), new tires, wheels, cooling system, shocks, lock-outs, etc. Nothing fancy, I like stock and clean.
Hello everyone. Pretty new here and have found a lot of great info so far. I am having a problem with my 78 CJ5 . My Transfer Case engauges, front shaft turns, but no power to the tires? I was thinking bad lock out's?
Since we got some snow here I had a friend look at the front end as I went up a small snow bank. I did t in 2 high, then 4 high/low. The front drive shaft worked while engauged, but did not spin when in 2 high. So the transfer case seems to check out and apply power. The hubs will turn and appear to lock, but the front tires would not even attempt to grab or spin?!?!? Any info would be great. Thanks!!
Erich
Erich
out of it clean it with some brake parts cleaner and spray a little white lithium grease in there and your good.
